Help - How to restore / Determine IR Laser Crosshair X/Y Offset
I inadvertently wiped out my new IR laser module X/Y offset settings without
  1. realizing what they were used for
  2. writing down the values
    As a result, when I attempt to burn a design on a coin, it is offset from the material location.
    How do I go about either restoring the values or determining what they should be
If you connect to serial over a terminal you could reset the marlin-machine settings by M502 and saving it by entering M500.
I wish I understood what you’re advice entails. I’m not currently connected via serial (connected with Luban over wifi). Is there an alternate method to accomplish what you suggest?
Thanks
Sorry for the missing fact. You need to connect with usb to a computer.
Use the Usb-Mini-B Connector on the controller.
Then open Luban and connect to the machine.
Hopefully you can see your current settings by entering M503?
Then you could perform the M502 (for resetting the settings) and the M500 (for saving).
Maybe the reset would also work by a WiFi connection but I’m not sure.. Worth a try anyway?
Have a look here in the reset the controller section:
