Hardened Steel Hot Ends; Calibration?
I just replaced all four hot ends with the hardened steel version. I stayed up late to do that and figured I finish with the question of what next?
Do I run the Multi-toolhead Offset Calibration?
Do I tell the U1 they are hardened steel or does it not care? How about SnOrca?
I’m guessing filament calibrations would be a good idea?
Thanks for any input :sign_of_the_horns::sign_of_the_horns:
I think you should calibrate the bed and each toolhead nozzle coordinate as you did when you first got the machine.
Good question(s)
Thanks @Simon_Zhi :sign_of_the_horns::sign_of_the_horns: Sounds about right!
Ran the three Calibrations from the menu, now I just need to decide what to print…
