Howdy. I’m currently dealing with what I think is an intermittent, but repeatable on certain models, ghosting or ringing issue. I don’t think I’ve had this happen this much before, and not sure what is now causing it.
Example:
Squirtle’s eyes and mouth have obvious ringing.
I’ve done the calibrations for Speed and Max Flow, and Acceleration, along with the others from Teaching Tech.
For the Speed and Max Flow, all sections look fine-ish, but have ringing. 20 - 60, increments of 10
Acceleration
Set acceleration from 600-850, in 50 mm increments, with JD as .02 for all
All sections had the same weird effect which looks like bulging and ringing.
Then tried Acceleration 750 on all, with JD .01 - .06, increments of .01
So I copied brent113’s numbers.
M204 P750.00
M205 J0.02
Baseline cube print looks okay, can see some ringing on the left of the Y. Ignore the weird line as that is when the filament ran out.
I did Maker’s Muse ghosting test. No obvious ringing on the text I think, but some subtle ones of the edge itself, to the right of the logo. Similar to the cube.
Perhaps there’s a wobble on my A350? If I push down lightly on a corner on the bed, is it supposed to go down a little too?
I don’t know what else to try or fix.
Sidenotes:
My A350 is on a Husky workbench, with the snapmaker 2 enclosure.
I’ve done nivekmai’s extra part cooling fan on my v2 print head.
Here’s my current M503
G21 ; (mm)
M200 D1.75
M200 D0
M92 X400.00 Y400.00 Z400.00 B888.89 E224.90
M203 X120.00 Y120.00 Z40.00 E25.00
M201 X1000.00 Y1000.00 Z100.00 E10000.00
M204 P750.00 R1000.00 T1000.00
M205 B20000.00 S0.00 T0.00 P0.05 L3.00 C0.05 J0.02
M206 X-19.00 Y-10.00 Z0.00
M420 S1 Z0.00
G29 W I0 J0 Z7.15000
G29 W I1 J0 Z7.20000
G29 W I2 J0 Z7.20000
G29 W I3 J0 Z7.20000
G29 W I4 J0 Z7.15000
G29 W I0 J1 Z7.20000
G29 W I1 J1 Z7.20000
G29 W I2 J1 Z7.20000
G29 W I3 J1 Z7.20000
G29 W I4 J1 Z7.20000
G29 W I0 J2 Z7.20000
G29 W I1 J2 Z7.20000
G29 W I2 J2 Z7.30000
G29 W I3 J2 Z7.20000
G29 W I4 J2 Z7.20000
G29 W I0 J3 Z7.20000
G29 W I1 J3 Z7.20000
G29 W I2 J3 Z7.20000
G29 W I3 J3 Z7.20000
G29 W I4 J3 Z7.20000
G29 W I0 J4 Z7.00000
G29 W I1 J4 Z7.20000
G29 W I2 J4 Z7.20000
G29 W I3 J4 Z7.20000
G29 W I4 J4 Z7.05000
M301 P13.00 I0.10 D17.00
M851 Z1.00
M900 K0.07
Here’s my Cura 5.1.0 current speeds
