Gcode from Lightburn to Luban
My problem is that when I output gcode from Lightburn to Luban for my Snapmaker 2.0 with 40watt laser whilst the ‘run boundary’ correctly shows the area for the file when it starts to cutout the laser erratically moves around the area without powering the laser. The wooden ruler file from Luban works fine so the Snapmaker must be setup correctly. I have used the Snapmaker 2/40watt definition in Lightburn but am without success. Any ideas?
What origin type are you using in Lightburn? Are you using user origin, current position, or absolute coords?
