Fusion360 Laser Tool Settings
I have already used Fusion360 directly to generate g-code for CNC without Luban. Good video plus config files for the tools.
Does anyone have the settings for the laser? Or is it as simple to choose the tool and rename the file zu *.nc?
I just got frustrated as I constructed something in Fusion360 and exported it to Luban (svg/dfx) but the sizes dont match the original. Of course I did not think that could happen and only realised after cutting and assembling.
I gave up on Luban and imported the DXF from fusion into Lightburn to set out the pieces and generate the GCODE. I did use a generic laser too to generate a DXF including Fusion kerf but it was a right faf. I followed the process in this video.
In the last project I just exported a DXF from the sketch and used Lightburn for everything else including kerf.
