Fusion360 CNC changes
I’ve used Fusion several times for CNC cutting but they seem to have changed the setup interface. I used to just pick the tool but now it wants to know a bunch of info about the machine. Does anyone have a machine configuration file I can use?
Thanks.
John
Are you talking about when you post process now? It brings up an extra dialogue box but you can just ignore it and hit “post” and then it will let you name and save it.
It still uses the same file that you can get from the SM support pages. That hasn’t changed. Select the machine in setup.
Thanks for that. They change up F360 from time to time, so I wasn’t sure.
