Front Cover STL File & Replacement Kit Update (Dual Extrusion Module)
myA350hotendbrd.stl (3.0 KB)
finally… ive had these heads apart a LOT. the contacts for the hotends are very fragile and easy to break. this model has helped protect them and i would add them in any case. there are notches on one side and they should be facing the pcb board
