Just getting started with my laser module.
After some initial problems with the camera calibration, I’m now trying to fine tune the working origin.
Inside Luban 3.12.3 there is a option to fine tune the work origin:
Now, when I generate and load the G-code, it will always go to X,Y = 0,0.
That basically is outside my piece of wood board.
I can set the work origin etc, but this G-code does not take this into account.
Help !
Did anyone use this feature ?
How did you get this done ?
Maybe I’m just not using it properly, but my guess is just another annoying bug in the software ???
I have a SM 2.0.
So, not applicable to my device ?
The help in stoftware is not up to date ?
Since the instructions are already minimal, we do relay on proper help in the software snapmaker !
The method works although the instructions are somewhat weird.
Although they talk about work origin, this fine tune is basically a z origin adjustment, that is laser focus fine tune.
I ran it several times. I do not remember well, but in my test I selected the work origin with z=20 (do not remember exactly, 20 is an example) and I ran the procedure and got the 11 squares. Then I moved the origin to another position in my plywood, with z=22, and ran it again. I did it thrice to cover z in the range 20-24 with no problem (this range was a bad idea because it produces many redundant - same z - squares. On the positive, it gave me replicates to evaluate).
In summary, the procedure works for the 250 machine. Just try it, I was also a bit puzzled when I did it.
