If you sent it via wifi and ran it from the touchscreen it should work.
There’s a gcode command that will tell you if the runout sensor is being triggered: M119
When you get a chance to test, run that command from USB (won’t work over wifi, no response) with and without filament. One should say “open” and one should say “TRIGGERED”.
If it’s not getting triggered properly you’re going to have to make sure you hear a click when the filament inserts, and open up the side panel to adjust the microswitch. Something like this: Filament reload... Wait, it's not out of filament
