so far i dont understand all the crying about “the software is not complete”…. i really like it it has most features from orca wich are importatnt - compared to bambu it even has all fuzzy skin options!!! there are not many things wich need work in snorca!!!
but i found a couple bugs and think a few things need change…
maybe somebody from snapmaker will see it ![]()
1- when clicking on the device tab- the printer should automatically connect to the last connected printer
2- when sending a print job the same - the pop up requires you to select the printer again!
it should also automatically connect to the last connected printer
3 - when importing 3mf files from bambuslicer - the text is no text anymore its a object
should be also text when importing.
4 the device tab is too big… u have to scroll down to see everything.. .making it a lil bit smaller would allow everyhitng on one page!
5 snorca or orca both dont sync filaments….
6 snorca and the printer itself(display) need mor filament profiles to manually select from…more companies, bambulab, sunlu , jayo, etc…
7- no plate selection ability in snorca or the printer itself…
