Failed to load an .stl in to Luban for cnc Carving
Hello everyone
Today I run into some issue, as I tried to load an .stl in to Luban for CNC carving.
I tried software and the Browser Version, but same result.
Is there a max file size? Or is there no way to import detailed models?
It loads up to 12.5% and then the error occurs
Below, a picture of that Model.
There have been reports of Luban and/or the firmware choking on very large files (over 250MB gcode), although all the references I could find quickly were for 3D printing, rather than CNC.
You can always try alternative CAM software to generate the gcode—Fusion 360 is the most often recommended for CNC.
