[Example]Notification Setting Description Could Be Clearer
From Admin: This is just for iilustration
:pushpin: What happened? What did you expect?
The description for the Messages notification toggle is unclear. It states, “When turned off, only a red dot is shown.” but does not explain what is being turned off or where the red dot will appear.
I expected the description to clearly explain the behavior of the toggle, for example whether it disables notification previews, pop-ups, or only shows a badge on the notification icon.
Steps to Reproduce:
Log in to Snapmaker Models.
Go to Profile → Edit Profile → Notifications.
View the Messages notification setting.
Read the description below the toggle.
Expected Result: The description clearly explains what enabling or disabling the setting does.
Actual Result: The description is ambiguous and may leave users unsure what behavior the toggle controls.
Evidence: Screenshot attached.
Environment: Platform/PC Web
