i have a Snapmaker 2.0 350 with Enclosure and rotary modul.
Engraving wood was no Problem for me and i also understand what “fill and on the way” do. But now i have a Problem:
I have seen alot of pictures where someone engraved color coated stainless steel bottles. When i use “on the way” and use 6 time rerun the outline is very well engraved but the infill could not be run more then 1 time so the laser is not strong enough to do it well.
Has anyone ideas what setting i could use to get the the “fill” option to work on this project?
Run it multiple times. Usually with anything painted (or dry moly lube) I run it twice.
Not sure why they removed that option from fill in Luban.
Hopefully they’ll put it back.
Also make sure you’re running 100% power and maybe slow down.
