Enclosure and Emergency stop button
I just finished putting the enclosure together and realised that there is no port for the emergency stop button, does the emergency stop button work with an enclosure.
Add-on 3 for the Emergency stop.
Add-on 2 for the enclosure.
If you have the rotary tool or air purifier etc. then you need the hub:
Ok it looks like I need the hub
Your enclosure has both CAN ports used??
Add on 2 port has a different type of socket where the main pins are diagonal.
Share a picture? The estop plugs into the enclosure so I’m not sure why the plug would be different.
If I put it there where do I mount the stop button with at least some access to the button
Did you read the manual sdj linked? it’s on page 14 with a picture, right before the page I got that last image from.
oooops didn’t realise that there was a long cable in the button box, thanks
