Dual Extruder First Layer Issue
Has anybody posted an 11x11 macro for copy and paste for the A350 in Luban? Worried I might do something wrong
Does this help? 11x11 calibration with heated bed possible?
Not a Macro, but the commands… However, be aware that 11x11 currently does not work with the dual extruder :frowning: Bed Leveling/Adhesion Issues for the Dual Extruder - #5 by Jameracho
I have the same issue!
My prints are coming out exactly the same way. This is frustrating!!
For whatever reason SM can’t get the auto Z-offset right. So during your print you need to manually set the Z down, around -.3 to -.4 mm.
During the print, swipe right on the touchscreen and manually adjust the Z down until the print is correct.
See @Hauke’s explanation above.
Sorry for the thread necro, but did this ever get resolved in some way? Just installed my dual extruder recently and over the last 48hrs I’ve discovered needing to do this the hard way (literally watching many first layers print to figure out wtf was going on with my first layer adhesion)
Not to my knowledge. Even with the latest firmware auto-Z ist off for me. I now do manual Z, which gives good results. I am not aware Snapmaker ever acknowledged this bug.
Hello,
my soloution after many try but not perfect during your print you need to manually set the Right extruder Z down, around -0.2 mm Like @FAS sad.
for me most -0.2 mm but for you need to test it.
Thank you.
Yeah, that’s what I’ve been doing, it’s just not ideal though.
I had to recalibrate yesterday my artisan again. And had to do left -0.4 and right -0.2 again. Thats annoying, but it keeps the same values for that machine.
