Confused about how to use laser with real items (wallets, iPhone cases, etc)
Have you tried the Nixon methods to etch white tiles to be indelible to scratching off, etc? Curious if our lasers are powerful enough. It involves coating a white tile with some flat white paint, then burning with the laser, and at the end removing the paint with acetone, etc - this leaves a dark etched image burned into the tile’s surface.
Here’s my first ever tile burn with the settings above, with a white tile coated with black paint. My issue is the paint will scratch off easily, although I did apply a clear varnish topcoat but it’s still delicate. I inverted the image to a negative to have the laser burn the black off, revealing the white below. I’m pretty happy with it as a very first go although I wonder if it’ll be brighter with your settings.
I just downloaded Lightburn and I’m playing with it to see if it will do a better job especially if I try to make my own half tone dithered images, although this too is a big jump considering I’ve never done this before!
