Is there any Chance that there will be a Support added for CNC Touchplate.
So that the Homeposition Process is not killing the CNC Tip?
Other Idea is a other Cable connection on Heat bed. As example witrh an 90° Angle so that the Cable is not nearly cut when the Heat bed touches the Wall or anything else behind the Printer.
An other OPtion would be a Camera Addon Option.
