stepdown is preset to 0.1 or 0.2
so if i change it to 0.5 (hardwood) or 1.0 will i get different levels in the 0.5 or 1.0 even though it is making 1 pass.
explained further : made a panda outline at 0.1 stepdown (1.0 total) - and it came out absolutely amazing with different levels (such as the leaves were green - so it wasn’t 0.0 or 1.0 but somewhere in between)..
if i (being soft wood) said stepdown was 1.0, would i get the same result? and the bit (or head) would cut shallower or deeper, depending where the software put the leaves (say the leaves were 0.4 - would it still do it).
thanks , does anyone know? using Luban, or would it do it for fusion 360?
CAM programming is not my forte, but as I understand what you’re describing, no, you would not get the same result. The result would be coarser in the level detail. I believe you would usually do that as a roughing pass, then possibly followup with a 3D contour or other pass to get fine detail.
Personally, fusion360, I wouldn’t use Luban for that.
Step-down just means the maximum that it will try to cut.
It will cut in between those levels as necessary.
What I tend to do when I have a question like this is set up a simple test scenario to help me understand how it’s working and reacting. I would create a simple black to white gradient. Then I would run that multiple times while changing the settings.
This is one I created to test image2surface in Fusion 360:
