CNC - Spindle not spinning... why?
Hello,
The drill bit of the CNC is not spinning and I have no idea why!
I have no error message…
I’ve looked into previous post without success.
Any tips and tricks are appreciated !
Here are my settings
-Snapmaker A350
-Luban 4.13.0
-In the gcode of my file, there is everything that is needed I think with the M3 P100 and the F1500 commands :
;Header Start
;header_type: cnc
;tool_head: standardCNCToolheadForSM2
;machine: A350
;renderMethod: line
;file_total_lines: 488
;estimated_time(s): 1909.089
;is_rotate: true
;diameter: 35
;max_x(mm): 37.9
;max_y(mm): 12.9
;max_z(mm): 80
;max_b(mm): 0
;min_x(mm): -37.9
;min_y(mm): -12.9
;min_b(mm): 0
;min_z(mm): -0.095
;work_speed(mm/minute): 300
;jog_speed(mm/minute): 1500
;power(%): 0
;work_size_x: 320
;work_size_y: 350
;origin: center
;thumbnail: data:image/png;base64, [very long series of numbers and letters here]
;Header End
G90
G0 Z80.00 F1500
G0 X-37.90 Y-12.90
G0 Z1.00
M3 P100
G1 X-37.90 Y-12.90 Z-0.10 F150
G1 X37.90
Thanks a bunch for your help!
Are you able to turn the spindle on and off manually through Luban’s workspace?
I could not.
However, one more reboot did the trick and it’s back to normal. Very weird behavior.
So it’s now solved but… by chance ?!
Double check all your connections, might be a loose connection from the toolhead or the controller.
Glad to know it works now. Sometimes things just need a good reboot.
