Has anyone modeled the CNC platform?
From my work on the alignment tool, I can tell you that the outermost clamp screw holes are 120mm apart and as you move inward, the hole spacing shrinks 20mm per level, with the levels being 10mm apart. In other words, the x,y distance for each diagonal screw hole relative to the adjacent one toward or away from the center is 10,10 mm.
No, but i plan to do alot of holes to better flex to hold the stock…
