While trying to engrave, the CNC module stays at the top and engraves while it’s all the way up at the top of the very top post. So it’s engraving at the highest spot in the air. I can’t figure out how to get it down on the XY axis where it should start.
You have to move the bit to the top of your piece and set the work origin. Generally in the center of your piece. Then raise it up so it’s higher than any clamps and run boundary to make sure it’s not going to run into anything or go off the work.
