CNC ER11 Collet/Holder - can it hold larger diameter?
I see online ER11 collet sets (example here) . Can this be used with the CNC module of snapmaker2? To be clear - with this, it would be possible to use carving bits that are larger than 3.175 (1/8in) right?
Thanks
That link shows ER20 collets which are larger.
This link:
shows 7mm as the largest size.
Have you tried using 1/4" / 6mm router bits in the Snapmaker 2?
No. But they should work. You probably can’t push them too much depending on your material.
Yes. All the time.
