Change new linear module
Hi, I have A350 and I want repalce old modules (big noice) with a new modules. What should I buy ?, Only complete new modules? That is all?
Thank for your answer
Adrian
Hi Adrian.
Basicly, yes. You buy them and replace the old once with the new once. You should also make sure to have the latest firmware on your controller. Outdated firmware versions so not support the new linear drivers.
If you don’t already have solved the problem with the loud power supply you should also upgrade this to the new version.
The new printing head is not a must in the means of noice reduction.
Regards,
Thomas
Ok great, thank you, first of all I’ll try to replace the fan, for the quiet type …Yesterday I revived the 10w laser module, so I installed the firmware on the latest one…
