Causes of m1012?
any ideas
what cause this?
The M1012 gcode command was only added in one of the latest firmware upgrades. It looks like you don’t have that one installed yet but you are using a recent Luban version that does assume the last firmware version.
It’s related to the emergency stop button.
many thanks for explanation
Newbie here, still learning. Hooked up a laptop to work from the console and was getting the same command spuriously while in the console. I don’t have the stop button and was getting this as an echo. Any known reasons for seeing this when connected serially?
i think if you update the firmware and latest Luban via touchpad it should go away
but im pretty much a newbie too !
Hello,
I’ve got the same problem here…
Running Snapmaker Luban 4.2.2.
Is it a firmware issue ?
Pretty lost atm …
The solution
as far as I know its firmware which needs updating via the touchscreen
select settings option after swiping the screenand then select firmware update
it will then download the upates and then apply them
takes about 5-10 mins
Seeing the same errors come up after updating Luban to 4.70 and Snapmaker 2.0 A/AT/F Models
firmware to Snapmaker2_V1.15.21
ok
echo:Unknown command: "M1012"
others < SC req FW ver
snapmaker-luban 4.7.0
Connected via Wi-Fi
G53
ok
G28
X:-19.00 Y:354.00 Z:327.17 E:0.00 Count X:0 Y:143200 Z:133600 B:0
ok
