[Cash Fund] BrokkrSculpt — sculpt colour and material you can trust to print on the U1
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
MakerViking
Project name
BrokkrSculpt
Project URL
Project cover
Project Category
3D Model Editor
Project Summary
BrokkrSculpt is a free, open-source (AGPL-3.0) desktop sculpting app built for printing on the Snapmaker U1. It sculpts signed-distance voxel material instead of a mesh: cuts close themselves, STL/OBJ/3MF imports become sculptable solids with defects shown instead of silently “fixed”, and export is refused if the result would not be watertight. Open beta on Linux, Windows and macOS (Apple silicon): draw, clay, smooth, inflate, pinch, flatten, move and paint, with tablet pressure/tilt and SpaceMouse. 1,411 tests pass, and three performance gates fail the build if a budget is blown. Site: https://tinkeratlas.com/brokkrsculpt
The U1 path ships today:
  • Paint with what is loaded. “Sync filaments from printer” reads vendor, material and colour per tool head from the U1 over Moonraker (print_task_config); the paint brush writes those filament slots into the voxels.
  • Full Spectrum. Every pair of heads at 1:1, 2:1 and 1:2 — 22 paintable colours on four heads, drawn with the same colour model Snapmaker Orca uses.
  • Colour as print instructions. The 3MF writer tags each triangle with its slot (paint_color), not RGB; slicers ignore the 3MF colour extension (zero colorgroup/basematerials across two measured real projects).
  • Open in Snapmaker Orca. The sculpt opens on your U1 preset with your filaments and mixes set; Snapmaker Orca’s Print sends it to the machine.
Phase 2: colour and material you can trust to print. Delivered in this order, each verified on my own U1:
  1. Colour printability guard. Brokkr already refuses geometry that would not print; Phase 2 does the same for colour. It flags Full Spectrum mixes painted on surfaces too flat for layer alternation to show (the slope limit measured on test prints, not guessed), colour islands narrower than one extrusion line, and painted slots that are empty or mismatched on the machine. It predicts tool changes per layer and checks the prediction against the T0–T3 count in the sliced G-code.
  2. Multi-material solids. Paint becomes a volume, not a skin: a TPU skin over a PLA core, soft grips, flexible joints. The U1’s independent heads feed TPU, which AMS-style systems cannot. Because Brokkr owns the voxel field, it generates interlocking geometry at the boundary between materials — something a slicer, which only sees surfaces, cannot express. Evidence: pull tests of flat vs interlocked PLA–TPU boundaries printed on the U1.
  3. Colour scans to a U1 print. Import a colour scan (textured OBJ/PLY) and reduce it to the loaded filaments plus Full Spectrum mixes by perceived colour difference (CIELAB ΔE), limited to what one extrusion line can print. Colours are matched against a measured model: a calibration tile printed on the U1 and photographed against a reference card, published as an open dataset.
Evidence, in one reply before 23 Dec: U1 print photos, sample 3MFs, the G-code tool-change comparison, pull-test numbers, the colour dataset, and the test log for each feature.
Timeline, for transparency: BrokkrSculpt was designed for the U1 from its first commits (Aug 2026, e.g. a98a96a: “Hand a sculpt to OrcaSlicer, and watch the U1 print”) and developed in public ahead of Phase 2. Phase 2 funds the three items above; competition-window work is visible in the repo history and release notes.
Builder: Thomas Haugen / MakerViking (Norway). Brokkr is the sculpting companion to SindriCAD (Phase 1 Tier 3, $1,500) — a separate project, not a SindriCAD resubmit.
Open Source Status
Open Source
Please specify the open source license used by this project
AGPL-3.0-only
Cash Fund or U1 Hardware Sponsorship
Cash Fund
Originality
Original New Idea
If based on an existing project — your independent contribution
N/A
Is it a paid project?
No
