I generated a gcode from a dxf file using Luban.The gcode loads ,goes to origin ,moves to work start, and spins and spins and spins. I am a novice user and don’t fully understand the create tool path language. I don’t know what I am doing wrong.
Edwin
May 6, 2021, 2:43am
2
Please share your G-code file so that we can look into it.
Cheers
Edwin
bflowerteapotDXF_46424048.rar (1.3 MB)
I hope this helps and Thank you
Suzanne
Edwin
May 7, 2021, 7:46am
4
I have tried the file, bflowerteapotDXF_46424048.cnc, and it works well. I set the work origin at a high position and just to make an example.
Please update the latest firmware via this link:
Apr 27 2021: Snapmaker2_V1.12.1
Thank you for your suggestions on how to make the Snapmaker 2.0 better. Your feedback is always appreciated. Here comes the latest version of the Snapmaker 2.0 firmware.
Changelog
Controller
New Features
add “M413” G-code for enable/disable Power-Loss Recovery (#92 )
Parameters
[S<enable>] S0/S1 for enable / disable Power-Loss Recovery
e.g. M413 S0 disable Power-Loss Recovery
add “M600” G-code for replace filament manually (#93 )
You can add this G-co…
