Can't Process Cuts and Engraving
After updating to 3.15.1, Luban no longer allows me to process cuts and engravings in the same file - it seems like I’m only able to process one object in a file now. I used to be able to create G-Code that cuts and also engraves in the same session, giving the laser two different settings per object in my file. Now, Luban is only showing me one of the two objects I have processed. The text in my objects also show, but then aren’t processed - they don’t show up in the process preview.
Hi @tiff.tarampi ,
I ran into the same issue now and this is a workaround solution.
The problem, for whatever reasons is the cache folder.
Close Luban, empty cache folder, restart luban, reload file and the processing will be done properly.
Cache Folder : %Appdata%\Roaming\snapmaker-luban\Cache
Delete all files in the folder.
It would be very appreciated if the Luban creators could add an “empty cache & reload” button, as I found this to happen quite often and until one realizes that it’s again the cache folder is a bit time consuming.
Cheers
