Hello,
First of all, let me introduce myself. I’m not new to 3D Printing but this is my first Direct Drive printer and let me tell you this is giving me headaches to calibrate properly. For those tests, I used SM A250 with the official enclosure. The enclosure fan is turned on at 100% and I’m using SM fillament. I used cura and my test profile is provided at the end of the post.
All images here since a new member one could put one image: Teste - Album on Imgur
So, at first glance, I leveled the bed and checked it. Per the following image, it seems I have a nice first layer:
Couldn’t do PID Autotune cause it simply “crashes”.
Then, I decided to create a baseline cube for further comparison (yes, its not good):
At next step, I decided to check the extruder e-steps. I had a value E235.79 initially, and after extruding 100mm from 120mm, it extruded 11mm more, so I decided to change my values to E216.32.
Next step was checking the flow rate. Made a vase cube and this is the outcome:
The flow is almost perfect, the walls are smooth as silk. The average ratio was 0.4175mm per wall, so I changed my flow to 95.81. So far so good!
Next step was to check some retraction settings. After print this test, wich is made from segments of 0.20 from 0.40 to 1.40 as retration, I almost saw no change, so I left it with the default value of 1 and was too far from being so smoth as vase cube .
Finally, made a temp tower. I noticed the best temp is 200º, but it seems I’m under extruding and not even smooth as the vase cube.
As the last test, I’ve made a cali cat. As you can see, it’s bad. Very bad and not smooth.
Cura Profile: https://drive.google.com/file/d/1CWEXi8t0NrKCYSix20a4WdJfGrONbLKl/view?usp=sharing
So, I’m out of ideas in what can I do more. Would love your help to try to solve those issues.
Hope that I made enough tests to get your help.
Thanks.
