Cant Customize using Snapmaker Luban 3.13.1
I need some assistance here i just downloaded Luban 3.13.1 and now i can no longer customize my settings… Can anyone assist me???
Click the little gear icon:
it’s now in a separate pop-up window
i have the same issue. even in the new window I can’t change any thing. I just get greyed out boxes and a dashed circle saying you cant click. I cant even check the supports box. there used to be a plus button that you clicked to get pass this but that’s gone
If you have customizable profiles they will show up in the pull down menu left of the gear.
If you only have defaults click on the gear.
Select a default profile as your basis and copy it.
Then you can select under menu (if it doesn’t automatically) and edit it.
copy did the trick. thank you
