Can not load a Project into Workspace
Hello
I created a laser template with Snapmaker Luban. I used various .svg files for the template. Then I created the toolpath using vector toolpath. The G-code was then created. Everything looks good up to this point. Unfortunately, I can no longer import these into the workspace. This is then grayed out.
Which area is greyed out?
right bottom - Export → Load to workspace ( is greyed out) and Export G-Code to file (is greyed out)
for creating the svg files i used inkscape. The original is a pdf convertet via inkscape to .svg
So the export button is still black?
The Load G-code to workspace is normally grey anyway (and the other choice), what happens when you click it?
lol, yes normaly its grey but in this case is a other (not so dark grey) grey with a red crosed round sign if i hoover with my mouse over “load to workspace”.
Edit: I test it with some other projects and it works fine. Only one diffrent ist the size: Size is 100MB /
May Luban is limited by a size over 100MB?
