Can I use my XTool Rotary attachment with my A350?
I have the XTool RA2 Pro for M1 RA2 Pro for M1
Does anyone know if it is possible and then how to use it with the Snapmaker A350 and the Laser module?
Long story short, unfortunately not.
If you do some programming and build a custom firmware and use a can controller (or is it only the stepper connection inside the linear module?), maybe.
I can’t remember if this was posted in the forum in the past, hopefully some other users jump in, if I’m wrong.
Thanks
Search YouTube - one user made a DIY version of a rotary module compatible with Snapmaker. Theoretically, if you make the electronics shown in the video (PCB, Arduino, etc.), the Snapmaker controller will recognize the rotary module, and then the STEP & DIR signals for the rotation of the B axis will be generated in the Add-On2 socket - so you can connect any stepper motor.
The number of steps per millimeter (or per degree of rotation) for each axis is configurable using the M92 code.
