Booster fan speed management
Hello,
Is anyone has been able to reduce the booster fan speed using Gcode command…
I tried M2000 W2 P255 which put full speed and any value lower than 255 is not changing anything.
Thanks
Not that I’m aware of. The fan has three wires, so it’s possible that we’ll get it some time in the future.
Because of the new gcode reference it should be possible:
https://wiki.snapmaker.com/en/Snapmaker_Luban/manual/artisan_supported_gcode_references
M2000 W2 (Artisan) - Set Enclosure Fan
Description
  • Set the speed and switch status of the fan for the enclosure.
Usage
M2000 W2 P<n>
Copy
  • Parameters
    • P: Speed, from 0 to 100. 0 represents turning off the fan, 100 represents running the fan at full speed.
Examples
M2000 W2 P100
Ah, the “W2” must have been the missing link when I tried it a few weeks ago and it didn’t work.
Now they need to add fan speed control to the touch screen.
Thanks to xchrisd’s comment, I suspect any value between 100 and 255 does nothing expect maybe full speed…
That would be my guess. I haven’t tried it though.
