Artisan inside Enclosure Spool Holders
Hi there
got my Artisan a few weeks back and so far I am enjoying it.
My only issue is that the Spool Holders mounted outside are not easy to access for me and I wanted to move them inside the Enclosure. Now I tried on the side of the plate but filament keeps on getting stuck and pulling away.
So I am thinking of moving it to the back of the enclosure and while I’ve seen pictures (at least I think), I can’t figure out what the best approach is - mounting to the back of the Z -axis or or in the back with a standing holder or even attached to the enclosure on the roof?
Did anybody do this and has an idea to share?
Thanks - C.
Thanks, have this, but it does not work as I’d like. Waiting for longer PTFE tubes, but with the original length, the tube either gets stuck or drags across the heat bed.
will give it another try with the longer tube, but was rather looking for something in the back of the enclosure.
just a headsup, you can mount the factory spool holders to the back of your Z rails. I found the actual steps in the Artisan setup guide if you follow the one without the enclosure, although they still mount great inside with the enclosure.The video here shows it, I just mounted mine upside down for my spools are lower than in the video.
Should be around 1:28
Thanks! Did never saw this, but will try it - appreciate the help and search for it.
