Artisan Firmware Updates: V2.8.1 & V2.8.0
Hi everyone,
Two firmware updates for Artisan are now available. Here’s a quick overview of what’s included in V2.8.0 and V2.8.1.
V 2.8.1 | Wiki Release Note
Improvements
  1. Optimized the heated bed zone heating strategy: when the center zone temperature is above 80°C, the outer zones are automatically heated to 80°C to reduce PEI plate deformation during high-temperature printing.
  2. Added a reminder to adjust the flame sensor sensitivity.
  3. Optimized the flame sensor sensitivity to reduce false triggers.
  4. Optimized dual-nozzle lift status detection to reduce false alarms.
V2.8.0 | Wiki Release Note
New Features
  • Added Direct Machine Connection support for Snapmaker Orca. You can now send G-code to your machine over Wi-Fi without using Luban as a transfer station. Snapmaker Orca communicates directly with your machine through the OctoPrint protocol.
  • Added a Repeat Job button on the touchscreen. After a 3D printing, laser, or CNC job finishes, you’ll see an option to repeat the job and start it again with one tap.
  • With the beta firmware you no longer need to open Snapmaker Luban first to establish the connection. The only difference from before is the IP-address format, which now becomes: current device IP:8080 , e.g., 192.168.0.1:8080 .
For detailed steps, please refer to Snapmaker Orca Quick Start Guide for Artisan, 2.0, and J1/J1s.
Known issues
  • When using the single-head dual-nozzle setup for bed-level preheat or XY-offset calibration, uploading & starting a print from Orca will interrupt the calibration.
  • Uploading & starting a print from both Snapmaker Luban and Snapmaker Orca at the same time will cause the job to fail.
  • In some cases, sending a file via Snapmaker Orca may stick at 0 % upload progress; if this happens, restart the machine and provide logs plus a description of the problem.
  • When using the rotary module, the “re-print” function may occasionally restart the job at a different origin.
