Artisan Dual Extruder Offset Calibration
Does the Artisan have an automatic calibration routine for XY offset calibration like the J1? Or does it require you to print a line pattern like a lot of other printers?
Also - do we know how far apart the two extruders are?
Hi leonhart8888, I think Artisan is more like the latter one. After you’ve selected the Best Pair of Lines in the printed line patterns, Artisan will automatically calibrate the X and Y offsets of the two nozzles accordingly by making real-time compensation, as in the following graphic.
iShot_2022-12-14_11.02.18
The default offset in the X orientation of the two nozzles is 16 mm.
Hope it’d be helpful!
Thanks Riskey! Where did you find this info and graphic from?
Just curious - do we know what the default offset value is in that equation?
Thanks.
The default X offset of the two nozzles is 16 mm. The info and the graphic come from the Quick Start Guide (included in the package), which will be available online soon. I know it in advance because I’m the writer :laughing:…
Amazing thank you! I realize you wrote that info down in the last post but I just didn’t see it, sorry!
I’m actually asking because I use a tool for calibrating my other dual extrusion printers and wanted to make sure it would work for the Artisan - see here is you’re interested: https://www.emberprototypes.com/products/cxc
Thanks again!
Our PM said this tool would work for Artisan. You could give it try.
Sounds good, thanks!!
