Artisan 20w laser module compatibility
Hi Everyone!
I was wondering what the difference is between the Artisan 20w laser module and the 2.0 20w laser module (if any) and whether I could use the Artisan variant on my Snapmaker 2.0. It’d be great if anybody has any insights into this!
From this (https://support.snapmaker.com/hc/en-us/articles/7313412038551-How-are-Snapmaker-Artisan-and-Snapmaker-2-0-compatible-with-other-modules-and-addons) I assume that there is no difference/its the same module
Isn’t there a difference between the cables delivered with both? See this page and click the different Snapmaker. Snapmaker 20W & 40W Laser Module With Air Assist - Snapmaker US – Snapmaker EU
With Artisan a own quickswap kit is delivered and I guess it’s not compatible to the 2.0 quick swap.
The 2.0 need the power extension cable connected to the toolhead-port and the add on-port (like the 200W CNC).
So, buy a extension cable and a quickswap plate for 2.0 and you should be able to disassemble the Artisan quickswap plate to mount the 2.0s.
