Advice for the New Guy?
Temp. Tower, section 4. FINETUNE YOUR SOFTWARE SETTINGS TEST-SECTION
I would suggest to calibrate your k-factor (linear advance), the most people in the forum use a value between 0,08 and 0,1 (if you do the test from the following link, you have to edit the gcode, the "K"´s have to be small “k”, because of firmware!!)
