Skip to bottom for downloads if you don’t wanna watch me ramble lol.
The issue
So after working with the J1 for a while I had a case where I needed to spit out nearly 1KG worth of plastic in one night for parts that I needed the next day. I swapped to 0.6mm nozzles and immediately found out my print speed was almost entirely capped volumetric flow.
At 0.3mm layer height the print speed was a measly 70mm/s, I managed to finish the project on time but that really showed me the limitations of the V6 design on the original hotend. So I made my 0.6mm nozzle pair into volcanos, the volumetric maximum can now reach nearly 40mm^3/s and can comfortably print at 120mm/s with 0.6mm nozzles! But this came with a new host of issues.
The Solution
The Volcano hotend is a whopping 8.5mm longer then the original v6 design + the extra 3.5mm from my hotend using a volcano adapter as a spacer instead of a custom part, that’s almost 1.2cm of extra height! The original brackets just won’t cut it and since I fully intend on using the original V6 style hotend for 0.4 and 0.2mm nozzles so I made this adjustable nozzle wiper.
The wiper is fairly low profile, not much larger then the original and is relatively light, the height is adjusted using a thumbscrew (assembled with a M4x40mm screw, 10mm washer and M4 nuts).
Download
Download the adjustable wiper here here: Adjustable Wipers by mehlawlarz - Thingiverse
Also due to the height difference the original part cooler is practically blowing straight on the heater block, which is not good at all.
You can find a version of this part cooler for the volcano from: J1 Cooler and stuffs by mehlawlarz - Thingiverse
