A G-code path goes beyond plate boundries
I just downloaded Snapmaker Orca 2.3.0. Now I’m getting this error - “A G-code path goes beyond plate boundries”. It is the wipe tower causing the problem. If I turn the wipe tower off, It slices without issue. Is there a way to fix this?
yes, you can click on the wipe tower and move it inside the playground.
Thank you
