3rd party laser modds
Has anyone modded the Snapmaker 2.0 to handle a more powerful laser? I am looking at htttps://www.endurance-lasers.com/ they offer a 10w laser that can cut through much more than the 1.6w that comes with the 2.0. It can go through 5mm plywood in 2 passes, it is totally worth the upgrade. I use LightBurn since Luban is weak to be polite. I’m just not sure of the modd and if it is biting off more than I can chew.
Other than the rumored 7W laser module from Snapmaker, no, no one to my knowledge has changed the laser
https://endurancelasers.com/ has a 10w that I’m drooling over. This would make the 1.6w a toy that comes with the 2.0. I never knew lasers were so useful until Snapmaker. I just wish they were robust.
I haven’t even started with the CNC, my mind might be blown!
dang… lol that is pretty sweet.
i wonder how it would play with the snapmaker exactly
i havent even touched the laser or cnc yet.
I presume you still use g-code or some variant on it - do you suppose this uses the same language?
It uses LightBurn just like the Snapmaker laser, and uses g-code.
That looks really cool! If it can be added to the Snapmaker I’d be very interested - following…
