here is a summery of how to calibrate your E steps, more info can be found in the first thread i linked earlier.
for bed calibration, on the last step adjust down until you can just start to feel resistance on the card, there should be no buckling or bending of the paper. then when you start your print, if you have adhesion issues (filament does not want to stick to the bed) then adjust the Z offset down in small increments. here is a visual aid:
keep in mind that this machine has some backlash, meaning if you step down (in the direction of the bed) by .1mm it will go down .1mm but if you step up (away from the bed) by .1mm it will go up more the .1mm so if you get to close rather then just stepping up by .1 step up by 1mm and then bring it back down again.
