24 verified bug fixes for Snapmaker Orca — unblocking CLI slicing, the U1 nozzle lock, and multicolor toolchanges
I have read and understood all rules of the Innovation Fund Phase 2
on
I consent to my project information (username, project cover, summary, etc.) being publicly displayed for review and showcase
on
Username (for public display)
creat3dworld
Project name
Project URL
Project cover
Project Category
Software
Project Summary
I set out and downloaded several AI models and used them to start solving problems that were plaguing the environment. Snapmaker Orca runs part of the farm, the U1 side, and it kept breaking on us. The command line wouldn’t slice. The nozzle setting was stuck. Multicolor prints came out wrong.
I had to work through each step of the fixed code, directing the AI on where to go next and what to fix, and when it fixed it wrong, redesign the fix. We went through all 60 open bug reports and fixed 24 of them. 17 of those are pull requests now, waiting on upstream. I tested the results and created a platform internally for testing the code fixes in a more live implementation.
Open Source Status
Open Source
Please specify the open source license used by this project
GNU AGPL v3
Cash Fund or U1 Hardware Sponsorship
Cash Fund
Originality
Improvement / optimization based on an existing project
If based on an existing project — your independent contribution
The command line was dead first. That’s where I started.
  • #1184: a bare slice failed every time because it checked a printer that doesn’t exist. I made it load the saved presets instead. PR #1186.
  • #689: the CLI crashed loading any U1 preset because it used a nozzle size before checking it was there. That one needed a null check. Upstream already fixed it after 2.4.1, so no PR from me.
  • #935: the CLI rejected 3MF files the app itself wrote, because the version check compared the wrong version. I fixed it to read the app version. Someone else’s PR #839 already covers it, so I didn’t file a duplicate.
  • #717: gradients from the CLI came out flat 50/50 because the infill splitting only switched on in the GUI. I made the default match what the tooltip already promised. PR #1201.
  • One I found myself, no issue filed: a bare CLI run finished but produced no .gcode anywhere. With no output folder given, the file went to a temp folder the CLI deletes before it returns. I made it write plate_1.gcode to the working directory. My first version of that fix failed its re-test, so I corrected it and re-tested. All four runs pass now. PR #1210.
Then the U1 wouldn’t set up right.
  • #1185: the nozzle dropdown was stuck on 0.2 mm. It only listed presets marked visible, and if fewer than two sizes were visible it switched itself off. I made it list all the system presets. PR #1189.
  • #1143: the stock start G-code moved to Y1, which is out of range on toolheads 1, 3 and 4. Changed it to Y5 in all four presets. PR #7 on the profiles repo, since the presets live there now.
  • #790: the bed-mesh check looked for a bed type called Smooth PEI Plate that doesn’t exist, so the smooth plate never got its Z offset and the first layer printed too high. It checks for the right name now, High Temp Plate. The profiles repo already had that right, so no PR from me.
  • #957: you couldn’t turn on adaptive Pressure Advance at all, and per-filament ironing overrides didn’t exist. Both work now. PR #1193.
  • #1064: small area flow compensation never did anything. The setting was never applied before the export check. It is now. PR #1195.
Multicolor was the worst of it, since that’s the whole point of the U1.
  • #1119: the prime tower switched off when four filaments shared a preset name, because it only looked at the name and collapsed four colours into one. It looks at the colours now. PR #1190.
  • #1130: multicolor plates with a prime tower crashed, or lost which extruder was which. The tower list was shorter than the filament list. PR #1139 from another contributor covers it.
  • #1083: after a tool change with no prime tower, the head lost its Z clearance above 1.9 mm. The parser read a relative lift as absolute Z. The head could hit the print. I made it track relative and absolute mode. PR #1191.
  • #908: a dry PETG scrub during tool changes broke the prime tower on PLA to PETG prints. I took out the extra retract around the gap-wall ironing. PR #1192.
  • #1085: the wrong retraction length on tool changes when filaments use different flow variants. Tool 4 got tool 1’s value. The patch came from the reporter, F1rstd1ve. I verified it and adapted it. PR #1194.
  • #614: subdivide mix layer heights leaned toward 50/50 even for a 33/67 blend. Upstream already fixed that one after 2.4.1, so no PR from me.
  • #786: colour-mix matching stopped past 32 filaments. The batch add has room for the ones the cleanup is about to free now. PR #1200.
  • #878: the warning said same type when PETG and PCTG are actually compatible. It says compatible filaments now. PR #1202. Hiding incompatible mixes entirely needs a bigger rework, so that part is still open.
And the crashes, the lost logins, the broken downloads.
  • #616: after syncing filaments from a U1, the app crashed on every launch. Empty values went into a strict number parser. It parses defensively now. PR #876 from another contributor covers it.
  • #1109: open in slicer downloads saved as 0-byte files. Bad version test and a wrong callback. Both fixed. PR #1198.
  • #776: post-process scripts failed on Windows. I filed PR #1203 for the temp paths, but upstream pushed back, and when I tested it myself on Nov 24 the real failure was something else. The script reads the file with no encoding, so Python on Windows defaults to cp1252 and chokes on a UTF-8 byte in the G-code. Same failure on a copy renamed to .gcode, so the .pp suffix isn’t it either. PR #1203 doesn’t fix the actual failure. The fix belongs in the script.
  • #984: on Linux the Snapmaker login was lost after every restart because the cookies were never saved. They save now. PR #1205, and it covers #925 and #226 too.
  • #1009: bold and italic did nothing on macOS .ttc fonts. Identical fonts never compared equal because the comparison was backwards. Fixed the operator. PR #1204. The main face-index fix belongs to the reporter’s own PR.
  • #871: the bundled printer config couldn’t install on a fresh data folder. The check demanded preset folders for what is actually printer-definition data. Upstream already fixed that one after 2.4.1, so no PR from me.
How I checked it: every patch was verified against a fresh copy of 2.4.1. It compiles. The full triage log for all 60 reports, including the 31 with no fix and why, is here: OrcaSlicer v2.4.1 issue triage log — all 60 open bug reports traced to root cause (or assessed honestly), 23 fixes written, 24th fix filed as PR #1210 · GitHub
Why I bothered: these aren’t theoretical. They block the things the U1 is sold on. The command line fixes bring back a whole way of using the printer that was completely dead. The Z clearance one is a safety issue. Everything is submitted upstream as PRs, so every U1 user gets the benefit if they land.
What is needed from Snapmaker
I need a system that runs Linux, so I can test the Linux side on real hardware. Linux itself is free. The hardware isn’t, and I only have one system with enough power to run these tests.
I need more RAM for the test system, about $430 to $670 for 32GB.
I want to expand the Snapmaker side of the farm, so I need other Snapmaker printers to test on, not just the one U1. Another U1 is $699. The Artisan starts at $1,799. Different feeders and feeder types too, the feeder module is $16.99, and a multicolor tool head for testing, toolheads are $64.99 each.
I need filament to test RFID compatibility and errors. RFID rolls are $22.99 each, down to $13.11 a roll in bulk. (I’ll take smaller rolls and free rolls if you want haha)
The fund money goes to squashing bugs and 3D printing, and 3D printing hardware and systems for testing. The 24 fixes are already submitted as PRs.
Links
Is it a paid project?
No
Thank you! You’re quite an excellent tester.:grinning_face:
