2 watt ir laser calibration
Am I correct to assume that the 2 watt laser uses the same calibration block as the 40 watt? I should clarify that I am trying to use Input Material Thickness Mode.
Yes, it should be the same block.
The 2W IR laser has the same little drop down focusing tab as the 20w and 40w have, to set the focal distance.
