yes exactly
I assume the stronger CNC machine would still be capable of 3D printing. Iād mainly want the 3D printing capability to do small prints; I have a large format printer already to do larger ones. Iād have it set up as a CNC carver most of the time.
What Iād really like to see is a CNC module that doesnāt have so much runout, i.e. that uses a collet of some sort for holding the cutting bit more centrally instead of the single set screw. Iāll be experimenting with a couple of aftermarket collets on the existing module to see if I can improve things.
Bring the lazer PLEASE
The size of the print surface is a serious limitation if you want to make something useful. Sometimes the object can be rotated 45 degrees to make it fit, but that doesnāt always work. I really need longer X and Y axes.
The Double Z! Becouse its working-area is bigger, itās stronger and more precise and itās still as versatile as the smaller 3-in-1 Snapmaker.
I donāt think the Double Z they are showing has a bigger build area.
They definitely need to offer one with a bigger area.
I actually think the one with the Double Y would be more rigid.
If the double Y is also compatible to the other moduls, then it will be the best. But itās just called āstronger CNC machineā, that sounds like, itās just a CNC-Carver.
True. But I donāt see why they would limit it to just the CNC. Maybe they would sell it with just the CNC but the controller supports all the modules and shouldnāt prevent the use of the other modules. I guess it depends if they sell it as an āupgrade kitā or as a stand alone separate product.
simple lazer engraver for the sole reason that while a lot can be done with the current print area with cnc and 3d printing, the print area with lazer engraving feels like it is too small
The Double Z⦠two Linear Modules to handle the Tool Modules mean they are more precise.
That said, a larger Main Plate (the platform everything attaches to) would allow for two Linear Modules to support the Heated Bed/Work Area as well.
@whimsycwd Could you tell us if the stronger CNC would be able to 3D print as well? If not, PLEASE consider that feature. I donāt think you guys are understanding how much this product would be perfect in comparison to so much others in the market by just adding a larger build plate to actually print almost anything useful - and slicing and editing already made models is a PITA. Most of us just want to load the model and print it
https://de.wikipedia.org/wiki/Laser - nur damit Ćbersetzungsprogramme nicht überfordert werden
Wenn ein Ćbersetzer Schmarrn trotzdem richtig übersetzt oder in Zukunft hoffentlich übersetzen kƶnnen wird, dann dieser hier : https://www.deepl.com/de/translator
Are these products available for order ?
I would be very interested to buy some of them.
Thanks !
Not yet - Iād recommend checking the Snapmaker Store twice a month for updates.
