U1: Automatically include all eligible Auto-Refill backup toolheads in Dynamic Flow Calibration
When Dynamic Flow Calibration is enabled before a print, the U1 should calibrate not only the initially used toolhead, but also every loaded toolhead that is eligible as an Auto-Refill/backup source for the active filament.
Alternatively, the display should provide the options:
  • Used toolheads
  • Eligible Auto-Refill backup toolheads
  • All loaded toolheads
The calculated Pressure Advance value should be retained and applied separately for each physical toolhead if Auto-Refill switches tools during the print.
I’ll move this to Feature Requests.
Fully automatic calibration of all toolheads may first cause the pre‑print preparation time to jump from 1 minute to as much as 10–15 minutes.
Another issue concerns how to define “Eligible Auto‑Refill backup toolheads” – should it be the same color of the same filament type? There are still many filament types that cannot be clearly recognized by U1, e.g., SUNLU/eSUN PLA in red – both might be recognized as “Generic”.
An option that allows users to manually select which toolheads they want to calibrate seems like a reasonable compromise solution.
Another possible and potentially more intuitive integration point would be the existing filament-loading screen.
The user already selects the filament material and color when loading a spool. This screen could include an optional submenu or checkbox:
Calibrate Pressure Advance after loading
Pressure Advance would not need to be active during the physical loading process itself. Instead, the calibration should start after:
  1. The filament has been loaded successfully;
  2. The filament has reached the nozzle;
  3. The normal purge/loading extrusion has completed;
  4. The hotend has reached the selected calibration temperature.
Proposed loading workflow
  1. The user selects the toolhead.
  2. The user selects filament manufacturer, material, subtype, and color.
  3. The display shows the recommended calibration temperature.
  4. The user can change the temperature within the hotend’s safe limits.
  5. The user chooses one of the following:
    • Load only;
    • Load and calibrate Pressure Advance;
    • Load now and calibrate later.
  6. The printer loads and purges the filament.
  7. If requested, the printer performs the existing Dynamic Flow Calibration routine.
  8. The measured PA value is stored for that toolhead’s newly loaded-filament session.
After calibration, the filament screen could display:
  • Toolhead: T1
  • Filament: Generic PLA, Red
  • PA status: Calibrated
  • PA value: 0.0184
  • Calibration temperature: 220 °C
  • Nozzle diameter: 0.4 mm (may be still set in preferences)
Calibration lifetime
The measured PA value should remain valid until:
  • The spool is unloaded or replaced;
  • The filament assignment is changed;
  • The nozzle/hotend configuration changes;
  • The user manually clears or repeats the calibration.
Completing a print, switching toolheads, or restarting the printer should not invalidate the value.
The stored PA value should be reapplied whenever the corresponding toolhead is activated, including when it is selected automatically by Auto-Refill.
Benefits for Auto-Refill
This would solve much of the backup-filament problem before the print starts.
If every newly loaded spool can optionally be calibrated during loading, the firmware can determine which Auto-Refill candidates already have a valid PA value. At print start, the display could show:
  • T1 — used by print, PA calibrated
  • T2 — Auto-Refill candidate, PA calibrated
  • T3 — Auto-Refill candidate, not calibrated
  • T4 — unrelated filament
The user could then decide whether to:
  • Start immediately;
  • Calibrate only T3;
  • Recalibrate selected toolheads;
  • Continue using the filament profile/default PA value.
This avoids recalibrating every toolhead before every print and distributes the preparation time to the moment when a spool is loaded.
Backend considerations
The PA record should be associated with a loaded-filament session rather than only with the material name or color. Suggested metadata includes:
  • Physical toolhead ID;
  • PA value;
  • Calibration temperature;
  • Nozzle diameter/hotend ID;
  • Filament manufacturer, material and subtype;
  • Filament-session validity flag;
  • Calibration timestamp.
Generic material metadata should not cause a PA value to be copied between different spools or toolheads.
On an unload event, only the PA record belonging to that toolhead should be invalidated. A new load should create a new filament session, even if the user selects the same material and color again.
Failure handling
A failed PA calibration should not prevent the filament from being loaded.
If calibration fails or produces an out-of-range result, the display should:
  • Report that no valid dynamic PA value was stored;
  • Retain the filament as successfully loaded;
  • Fall back to the configured filament PA/default value;
  • Offer Retry, Change temperature, or Skip.
Relationship to print-start calibration
Print-start Dynamic Flow Calibration should remain available, but it would become a secondary option:
  • Already calibrated toolheads are skipped by default;
  • Uncalibrated toolheads used by the print are selected by default;
  • Uncalibrated Auto-Refill candidates are shown as recommended;
  • The user can still manually select any loaded toolhead.
This would create a consistent lifecycle:
Load spool → optionally calibrate PA → store PA → reuse for prints and Auto-Refill → clear PA when spool is unloaded.
@Zoe_M Is there an update on this feature request?
Feature requests are just that, requests… There is no guarantee no matter how many people vote for it that anything will be added, only considered.
Now add to that this only has one vote I would say its very slim currently…
Zoe_M makes a valid point about prep time, and I agree that automatically calibrating every loaded toolhead is not the right default. My request is narrower: I want to prepare backup toolheads for Auto-Refill before a long print, not every toolhead in the machine.
A lower-impact alternative would be an opt-in manual selection in the Advanced section, both on the touchscreen and in Snapmaker Orca. When Dynamic Flow Calibration is enabled, the user could tick additional toolheads to calibrate, but the printer would only offer the toolheads that it already considers eligible Auto-Refill backups for the toolhead or toolheads selected by the slicer, based on material type and color. This does not add new eligibility logic. It simply exposes the existing eligible backup toolheads so they can be calibrated manually.
This addresses both concerns:
· Prep time: nothing changes for users who do not tick the box. Only the person who explicitly asks for extra backup toolheads pays the extra calibration time, and they do so knowingly.
· Eligibility ambiguity: the printer already decides which toolheads are valid Auto-Refill backups by material type and color. The manual list would just let the user calibrate those eligible toolheads in advance.
In practice this would let me load the same PLA into T2 and T3, print from T1, and tick T2 and T3 in Advanced so their pressure advance values are ready if Auto-Refill switches mid-print, without forcing every U1 owner to spend 10 to 15 minutes calibrating toolheads they do not intend to use.
Would the team consider this narrower manual option?
It would be even better if you could determine the PA (Pressure Adjuster) directly when loading the spool, allowing multiple print jobs without pre-calibrating the PA to benefit from using the same spool.
Load spool → Optional: Calibrate PA → Save PA → Reuse for printing and auto-refill → Delete PA when spool is unloaded.
Saving PA per spool is an appealing idea, but PA is not determined by the filament alone. Klipper’s documentation is explicit that the pressure advance value depends on the extruder, the nozzle, and the filament. The U1 already reflects this: Dynamic Flow Calibration stores the Pressure Advance value per toolhead, not per spool.
Two toolheads can be the same model, see the same filament, and still land on different K values because of normal manufacturing tolerances, nozzle wear, and differences in each toolhead’s melt zone and extrusion sensor response.
That is why I would not want a single spool-level PA applied to a backup toolhead during Auto-Refill. If the switch happens mid-print and the backup receives a K calibrated on the primary, the print can drift into under- or over-extrusion right at the switch. The manual Advanced selection keeps the existing per-toolhead calibration and simply lets users prepare the eligible backups in advance, without changing anything for users who do not opt in.
In case the manual selection in Advanced is not implemented, here is a workaround that I just used on my U1.
Add primitive cube objects to the build plate and resize them into thin lines, one per additional toolhead you want to calibrate. In my case: 0.4 mm wide, 0.25 mm high, 27 mm long. Paint each line with the color assigned to the filament of the corresponding toolhead. Physically it is the same filament in all of them, but the slicer sees separate colors and exposes those toolheads for Dynamic Flow Calibration. After slicing and sending the print, both the slicer and the printer screen let you select those toolheads and calibrate them.
It works, but it is neither straightforward nor convenient. You have to add geometry, resize it, paint it, and clean it up afterwards. It also adds a small amount of G-code and print time, and it is not something a normal user would be expected to do. I am posting it in case it helps someone else while the feature request is under consideration.
