Top Cover Recirculation Fan
Recently (since firmware 2.0) I am having an odd problem.
When printing PLA, I tend to want the Top Cover External Circulation fan on high, to keep chamber temperatures down.
Now, I cannot enable that fan at all. I get a warning, when I try stating that Internal insulation mode is on, and the External fan cannot be enabled.
I’m not clear what this “internal insulation mode” is.
And since I cannot use the External Circulation fan, my chamber is overheating. I have had to remove the Top Cover to print PLA.
Have you tried controlling the fans directly from the control panel? It worked for me.
what temps are you seeing with the lid on?
Are you asking me? IIRC I’ve seen the chamber at getting on for 50ºC.
That was with the 2.0.0 firmware (I didn’t install my top cover until after the hi-flo trials). The other thing which might interfere is the Klipper macros SnOrca embeds in the G-Code file.
The OP since I just wondered what he considered “high” - My chamber hovers around the 40c mark with my printed lid and door closed during PLA printing
First, the main issue I am seeing, and don’t understand, is that I cannot adjust the External Circulation fan AT ALL. ONLY the Internal Recirculation fan is going. And when I DO try to adjust the External Fan, I get this warning/error “Internal insulation mode is on, the External Fan is disabled”.
The chamber temps I’m seeing depend on the material. For PLA, I get to 48C, which will stop the print. For PCTG, with a much higher bed temp, I was seeing 58-59C, which is too high chamber temp for PCTG. It starts stringing and prints fail.
Only way to solve problem, for now, is to remove the Top Cover.
Make sure to use a recent version of Snorca. It has commands in the Start G-Code to support the Top Cover.
You can also control the fans through the Fluidd (Klipper) interface by connecting to your printer ip from a web browser. Look under the Fans and Outputs.
Lowering the extrusion temp could help keep the chamber temp lower. I’d say the bed temp also, but it would probably affect first layer adhesion.
Are using the aux fan?
I am using 2.4.1 of SnOrca, and this also occurred in 2.4.0.
No, you actually cannot control the Top Cover fans in Fluidd.
This is clearly a Top Cover and/or SnOrca artifact. Removing Top Cover and problem goes away.
N.B. I have opened a ticket with Snapmaker Support on this issue.
I thought the same about fluidd, but it’s there as “Exhaust” and “Circulation” fan in the Fans & Output card. Maybe it was exposed in the latest firmware.
It’s amazing what one can find out when googling the warning message.
Edited to make it clearer.
I agree, but where in this discussion is an error measage discussed. Isn’t this about an issue that’s unrelated to an error message?
My 50ºC was probably with PETG. As noted elsewhere, it seems the chamber temperature sensor is not located in a very good place and may be over-reading.
