When downloading the STL file, the detailed settings about 3D printing such as material won’t display properly for some reason. I don’t know this situation.
Im not sure how to help with this… other than recommend using Cura or Prusaslicer… they are much better anyhow…
Do you need to select the object?
You should try changing the language or updating the firmware.
