Snapmaker2.0 1064nm Laser Module LightBurn Setting (Crosshair Laser Mark framing supported)
I purchased a 1064nm laser module last month, but I have not received it yet because it had to be shipped again due to a defective tilt sensor ![]()
A friend of mine came from Yokohama and lent me a 1064nm IR module that belongs to him.
I could not get the Crosshair Laser Mark to work with LightBurn, so I came up with an idea and was able to set it up.
I have also created a manual so you can try it out as you can use the markers for positioning and framing the object to be processed.
I’ve included a PDF file of the manual and the device settings on the A250.
*The translation is done from Japanese to English by automatic translation, so some nuances and expressions may not be correct.
Please understand beforehand.
Snapmaker2_1064nm_IR_Laser_Setting_Manual.pdf (2.8 MB)
DeviceProperty_Snapmaker2.0_2W_1064nm.zip (1.5 KB)
