Snapmaker Orca 2.4.0 fails to select Snapmaker U1
Steps to reproduce:
  1. Start Snapmaker Orca 2.4.0 on Windows
  2. Open your model file
  3. Go to Device tab
  4. Select Snapmaker U1 in the “My Devices” dropdown in the top left corner of the Snapmaker Orca window
  5. Go to Prepare tab
  6. Slice the model
  7. Click “Print->Upload and print” or “Print->Upload”
  8. Select your printer in the “Select Printer” dropdown (the dropdown which says “Click to select printer”
  9. Observe that it fails to connect to the printer and does not select any printer
If I instead skip steps 2 and 3, it works as expected: I can open the “Print->Upload and print” and select my printer and successfully start the print.
I suggest to try this out on 2.4.1 and report back.
when it fails, does the device tab itself still show the printer as connected? wondering if the selection sticks or the upload dialog reads a stale entry :thinking:
Works on 2.4.1 alpha
Yes the device tab still shows the printer as connected when it fails.
I’ve already reported that issue to support as well. My solution is to use LAN mode. So far, it’s been working great. And the camera is also faster on its own local network.
ah got it, so the connection itself was fine and the dialog just wasn’t reading it. glad 2.4.1 alpha fixed things :crossed_fingers:
