Snapmaker Luban error, Skin generated over random spaces
I’m having a huge amount of trouble figuring this out. Luban randomly adds a skin layer top surface over spaces that should be empty, holes… There are clearly holes there in the STL, and Luban even renders it correctly, but the moment I generate the G-Code, the hole is covered up with a yellow layer. It’s so bad that I have to slice what should be a monolithic piece into up to 6 pieces to eliminate the problem, and then glue it together.
That usually means your mesh isn’t correct, the vertices don’t line up correctly. There’s probably some random vertex off in left field that causes Luban to render a large flat plan.
Search the forum for repairing meshes. I’m not good at it though. I usually just start over from scratch and redesign my (simple) pieces.
Popping this up.
No this is a Luban issue. I have had the same thing pop up on several occasions. Particularly with gears.
Using Blender 3.5.0 and Luban 4.7.2 this still happens. I run the 3d print tools on a very basic gear and everything checks out: manifold, cont edges,intersecting faces,zero faces,zero edges,non flat,thin faces,sharp edges, etc… The design is clean and the exported stl generates fine in Prusa but in Luban the centre hole is skinned over. I did some experiments slowly removing parts of the gear to locate the issue. It seems to be connected with the bevels. If I remove any 2 bevels from one of the outer holes the issue resolves. If I remove 2 inner bevels from 2 different holes it resolves. I’m going to upload a gear stl with one bevel missing which will result in the skin over and one with 2 where the centre hole is clear. Grrrr So apparently I’m not yet allowed to upload. Punished for trying to be helpful. Okay so ascii art then. A gear similar to this one that has outer holes with beveled edges.
Simply upload to a oneclick hoster or something else like google drive.
What version of Luban are your running?
What OS are you on?
If you share your stl, parachvte may could analyse.
Looks like I’ve been given upload permission.
As mentioned these are cut down versions of the original stl where I was trying to locate the issue. They are not pretty. The 1bevel skins over the centre hole and the the 2bevel does not. Oh and if I slice the original gear standing on end it works correctly as well. As mentions above this is Luban 4.7.2 but I have seen multiple people post about this issue across the web for a few years now. 2020 was the earliest I think. I would not expect the the OS to mater but this on Ubuntu 22.04 as well as previous versions.
gear_merge2bevel7.stl (52.3 KB)
gear_merge1bevel7.stl (53.1 KB)
Both of them slice fine in luban 4.6.3. No skin over center hole.
Can’t speak for that version but in 4.7.2 you get this
i’ll upload the gcode as well
gearmergebevel7.gcode (3.7 MB)
Lol. It’s the same in Luban 4.7.3, but It seems to slice well in Cura, Prusa and Ideamaker…
Weird issue. Seams like a bug. However, if you change wall line count, you can get it to work. Line width also seams to have an impact…
Sorry for the late response. Been on vacation.
Thanks for the reply and good spot on the count. Simple work around.
